All 650's 2018 CB650F won’t start.
Status
Not open for further replies.
Lukeperna
May 14, 2020
Hey I have a 2018 Cb650f that Won’t start. My friend backed into it and it tipped it over when it was idling. I shit it off and picked it up everything was fine I ordered a new tank because it had a dent in it and a new clutch cover. After I replaced the gas tank I started the bike it ran fine. A few days later I replaced the clutch cover and let the gasket maker dry for 3 days and when I went to start go and start it, it won’t start it cranks but won’t turn over. I checked all the fuses and relays has fuel the pump is turning on when I flip the kill switch to the run position. I’ve tried starting it in gear with the clutch in, I’ve tried it in neutral and nothing works. I’ve tried doing the flooded method of holding the throttle open when trying to start it and nothing work. Any advice to what it could be would be awesome. Thanks
Is the crank position sensor connected correctly? That's the only thing I can think of that would be disturbed by a clutch cover change.
Lukeperna
May 14, 2020
I put everything back in the same way as it came out. I have no clue.
I’m locking this thread because its a duplicate post. Please continue in the original location.
Did you check for spark and injector pulse?
Status
