To compliment the footrest position adjusting plates I made some weeks ago it was time to pay attention to the handlebars. As the position cannot be altered much if you want to keep the cable length standard I made these cresent shaped packers which have raised the bars 12mm and allowed me to rotate the bars rearwards by about 25mm without getting close to the tank. The dimensions are diameter 28.6mm circles (handlebar diameter) at 12mm centres and were turned on the lathe with a length of 23mm. The spacers at the front of the clamp are 12mm high, 20mm diameter with a clearance flat milled on them and all held together with m8 x 40 cap screws. Now the riding position is getting much more comfortable.
