- Mar 17, 2018
Why am I doing this mod?
I'm a short guy, my arms are almost fully extended, and I'm not a young guy. My back hurts.
The CBR500R handle bars are vertical, the CBR650F handle bars are angled forward. This would help bring the bars closer to me.
So far, I recommended NOBODY DO THIS MOD, because of safety issues I'm encountering. Maybe someone can think of a better way of doing it, and figure a smart way from my experience/nightmare.
Here's Part 1.
Removed Honda thing inside the bar, if you peer back your clutch grip and remove the throttle tube, you need to press in the holes in the end to push down on the tab to remove. Their are two tabs.
My picture shows them removed and hard to see.
A close up shot of the tabs
Holes in bars for the pins to hold the Controls such as signal, kill switch, and throttle do NOT line up.
Top picture is CBR650F, bottom is CBR500R
Had to drill holes in proper places.
Used paper and trace where the holes are suppose to be with the original bars, then transferred to CBR500R bars.
LEFT SIDE ISSUES.
The turn signal hits the tank, but it does not hurt anything, it's enough to be a cheap auto cancel signal if you turn the handle bar all the way to the left. Very Dangerous if you get a tank slapper, and your thumb is there!!!
The CBR500R handle bars, seem to sweep more than the CBR650F, something I didn't think of, when purchasing the bars
RIGHT SIDE ISSUE!!!!
A super punch to my D***, Missed drilling a hole. I'm unable to install the throttle cable housing.
Have to meet my friend to use his drill press.
Other Issues. The cable for the horn is too short, I unplugged it, and will have to cut the wires and make it longer.
To be continued.............
Here's Part 1.
LEFT SIDE ISSUES.
