All 650's Exhaust function video
Duncan
Honorable Discharge
Odominator
May 3, 2015
SEQ Australia
Nice one. I like that he listed a good amount of pros and cons to each system.
Something that should be added for our forum readers is that we seem to have 2 types of "back pressure"
One that is a resistance to gas flow, as shown in the 1st video where he talks about pipes that are too narrow. The other with comes from the manipulation of sound waves, as when the pipe diameter increases or a valve is inserted.
Additionally, I've just watched their videos on lubing steering head bearings and using WD40 on chain O-rings. That's a good channel with a straight forward presentation. Thanks for posting it.
Driftin
Amateur
Jun 8, 2017
Portland, Oregon
Nice video to help people learn that modern EFI bikes need different tuning. I've replaced a lot of pipes for more power. Now just to save weight and sound cool!! My CBR650F was about silent until I put on the new Akrapovic exhaust.
GPJake
Mar 8, 2015
United States / Northern KY
I'd like an akra every once in a while, but do prefer the quiet of the stock pipe.
Jerry
May 18, 2017
The Netherlands
My father had a custom Arrow exhaust installed on his Triumph Tiger Sport because he didn't like the look of the original exhaust. The dealer removed the dB limiter but my father actually had them put it back in again. He said the loudness of the sound was too much on extended rides. So I guess that's something to consider as well. It's probably neat if they can hear you coming from three blocks away, but if you end up hurting your own ears, it's not worth it.
My TBR is something like 8kgs lighter than stock. I imagine he akra wouldn't be much different.
The manufacturers website should tell you.
ADIOS600
May 16, 2017
LINCOLNSHIRE
I may have to think hard about 7 to 9 hundred pounds for 5 kilos plus a pcv.I did think about fitting a 2017 exhaust system what are your thoughts on that,I don't particularly like the looks that much.
