Hi there,
I am having issues starting my Honda CB650R 2019. To give some background to my predicament, I bought the bike used and it had previously sat for a month. It started up fine when I bought it, but the clutch plates needed to be replaced. I towed it home and it has sat in my garage for another month while I waited for parts to come in. I would start up the bike at least once a week to make sure it was running fine and I had no issues.
I recently opened the clutch cover and replaced the clutch plates. I am almost 99% sure that I did everything correctly (I am saying this so you know what you can eliminate as possible factors). However, I had to leave the clutch cover off for one night while I waited for my Permatex gasket sealer to arrive. After I finished installing the clutch cover, I let it sit for 24 for the gasket sealant to set. I then filled up the bike with oil to spec and tried to start the engine. When I turn the key on and switch the red switch on, I hear the noise of the fuel pump. I then hit the ignition and hear the engine loudly trying to start. It keeps turning over but nothing happens. I tried jump starting and that did not work. I tried putting fuel additives in the gas tank and tried engine starter in the air intake. Same thing every time. It is getting quite cold here at night and I am wondering if that is part of the problem. My next step will be to try and put a space heater beside it over night.
Does anyone have any thoughts? How do I get my bike started again?
