Hey there, I'm new here and hoping someone can help me with a problem I'm having with my CBR650F. I've owned it for three years without any issues, but this year I'm having trouble getting it started.
Here's what happened: I stored my bike in an underground garage for the winter like I have in past years, but this time I added fuel stabilizer to a full tank of gas instead of draining the tank like I did the year before. When I tried to start it up last week for the new season, the headlight and gauges came on, and the fuel pump primed, but when I tried to turn the engine over, it made bad sounds, almost like it had a dead battery. I tried jump-starting it with a portable car battery kit, and that worked, but the engine was running rough, misfiring, and the dashboard lights were flickering. The speedometer was surging up and down, and the RPM gauge was bouncing from 0 to redline repeatedly.
I tried to jump-start it again, and it worked, but it cut out completely after I rode it about 200 meters. I had to walk the bike back to storage. To check for major damage, I jump-started it again, and it started up with the same rough idle and flickering dashboard.
I'm not very familiar with motorcycles, but I know they need spark, fuel, and compression to run, and since the bike does run, I'm not sure what's causing the super rough idle and crazy gauges and throttle surging. I have charged the battery up to 100%, but before charging it, I checked the voltage, which was showing 12.05V in the bike.
Does anyone have any suggestions as to what could be causing this issue?
