All 650Rs Integrated tail light
Suspect159
May 4, 2021
I’m asking if anyone has bought the integrated tail light off Amazon or eBay for the CBR650R 2020 model? If so was replacing the relay necessary since it’s already equipped with the led lights??
m3_tristan
Oct 21, 2020
If you interested in those taillights, I would definitely get my tucked mount. I make these and have worked really well.
Mar 17, 2018
If the leds are round they are not bright and cheap (very old Technology). If they are flat they are SMD which are brighter. You want to be seen from the rear,
creef14
Jun 17, 2020
VA, USA
I bought an amazon one and have been using it for 8 months with no problems.
Amazon product ASIN B07WHWWHJX
You will need a flasher relay, otherwise the turn signal hyper flash. I would buy the one from TST and some of their wire adapters just because its easier than splicing.
2020cb650r
Apr 15, 2021
I have a 2020 bought all leds from tst and a flasher relay however on the 2020 it's a 3 pin flasher relay and tst has either a 2 or a 4 pin. So I can only have one set of leds rear and stock front to work properly
I have never messed around with relays much but I I plan to add additional flasher lights in the front and rear to run along side existing flashers, can this be done or do I need a special relay?
Tony650r
Nov 30, 2021
Hey what’s up, this was a while ago so you may have realized already. But in case you didn’t, yes the oem is a 3 pin relay, but the 2 pin gen 2 from TST works with oem lights and also aftermarket front and rear setup. They explain in the install video that the 3rd pin is a ground and that they designed theirs to work without a 3rd pin.
