CBR650F LED Blinker - OE Honda Vario for my CBR650F
victorkkq
Oct 30, 2018
Guys, just wanna share if you want to change your winker to LED but not into Chinese knockoffs, you can consider the OE Honda Vario. It looks exactly like the CBR650R but cost a third (not sure if it is available in your country).
mat34
Jul 27, 2020
Have You the oem number of each parts?
Do you change the relay?
victorkkq
Oct 30, 2018
M mat34 Yes need to change, Koyoko Winker Relay.
Take note the front winkers is abit short and the fairing might cover it. For me it is just nice as I don't like long winkers. So far I am happy with the results and some thought my bike is new.. ;)
mat34
Jul 27, 2020
Thank you.
For the winker it's 4 rear pieces. You use rear pieces on front?
They have 2 connectors. You have keep the OEM connector of the bulb light winker?
The adaptation in the front fairing is done well? the rubber are different from the oem rubber on cbr650r of 2020
You didn't buy the bolts to fix the winkers?
victorkkq
Oct 30, 2018
M mat34 Oh man now you are testing my technical knowledge. My apologies cause I let my dealer do the installation. I will try to give you as much detail as I can.
The winker is found only in Honda Vario Malaysia rear, which was used for my front and rear CBR650F.
I think the adaptation in front fairing is quite will done, it is abit shorter than CBR650R but for me it is much neater (see pictures to compare).
I am not sure about the connectors and rubber but I will take a photo of my original winker and remaining parts returned for you to see later.
No bolts purchased and the mechanic did not mention anything about bolts.
mat34
Jul 27, 2020
The front winner don't touch the fairing when you push up and down.
I agree with you it's better than no name winker. A beautifull oem winker is perfect.
victorkkq
Oct 30, 2018
The front winker is attached on the fairing and moves with the fairing. No knocking and very stable. No worries ;)
victorkkq
Oct 30, 2018
M @mat34 Guys.. this is embarrassing, I am no Macgyver to figure out the whats and hows. These items were returned to me and also a photo showing front winker under the fairing. Hope these helps.. Cheers ;)
