All 650Rs Multiple accessory's wiring advice
Hi All.
I am trying to figure out the best way to run the following accessory's.
My bike is a CBR650R 2021 and it already has OEM heated grips.
I am planning to install the following:
  • Quad lock wireless charging stem mount
  • Innov Dash cam front and rear (only one power source needed here)
  • Bike trak GPS unit.
I have done some research regarding power usage and the draw on the above is well in spec (not sure about the charger yet tbh, but I wont be using the charger all the time)
Now I trawled the forums and I know there is a connector in the front (Used for my heated grips) and another switched plug in the rear. So I have two accessory's that need to be powered.
Would you recommend installing some additional accessory connector block? has anyone experience on that and can advise?
Cheers!
Rafe
Oct 1, 2019
Info here where you can split the socket for the OEM heated grips and get yourself another connection.
Mar 17, 2018
You may want a power hub allow always on or switched.
I use stuff like this.
thanks for the sugestions guys, I see that Denali powerhub looks like somthing I could use but I see some bad review on it, hows it holding up for you bishop @bishop I might look around for other brands
Mar 17, 2018
I have the older one. which is similar to the Fuzebox, maybe you want to see it you can get it in your country.
The newer one my friends have it, and no issues. It's a pretty simple product.
Also, these always on or switched power hubs are basically car things, maybe you can look at car websites to find a similar product that will be small size and water proof.
On another note noticing you wanna get dash cameras. I have two innovv C5 cameras, nothing but head aches, firmware sucks, phone app sucks. You need really Samsung SD cards, not fake stuff from amazon. Save your money stay away from the C5 Camera.
looks good! thanks for the advice.
at leats the cameras record I had some chinese junk before and it did not last felet like a mug buying that.
