CB650R OEM handlebar weights replacements
Ern818
Oct 29, 2019
Slovakia
I bought pair of handlebar weights, looking at them when they arrived and OEM spare parst list, I now have doubt if I can fit them instead of OEM ones
Anyone has experience with replacement of OEM by aftermarket ones? Will they fit?
note: I did not managed to remove OEM one yet (it turns with screw...)
Pics attached
Rafe
Oct 1, 2019
They won’t fit. The OEM bar ends are notched and you have to align them up for proper fitment.
In order to get mine off when I did my Oxford heated grips I had to duct tape the bar ends to the grip and that provides a nice grip so they don’t spin when you remove the bar end screw.
Ern818
Oct 29, 2019
Slovakia
Thanks, Rafe
So, if I want to fit some other (nicer) bar end, where to find them? All I have seen looked like those I purchased...
MrFritz86
Sep 28, 2019
Nashville, TN
Thanks, Rafe
Puig bar ends don't require handlebar mods.
Seen the attached picture they should fit with stock handlebar weights. The small cut out (blue arrow) is the same as the stock bar ends.
https://puig.tv/en/tuning-motos/bar-ends/bar-ends-longs?bike=24111#responsivetab1
It seems only the Puig bar end with rim doesn't have the small cut out (even though the website says it doesn't require any mods to the bike)
iTom76
Aug 27, 2019
I used an electric impact driver to get the screw off. Just the screw rotated and not the sleeve inside. I replaced my handlebars with Renthals which have a thicker tubing and had to use the Renthal bar ends (which are not weighted). So far I haven’t noticed any vibration, but I have seen people add other weights when they felt the need to.
