OEM honda partsUnderstand. But the water pump and o-ring was honda OEM?
And what is to do?
and i don't understand the second question.
And what is to do?
you and me both.Thanks for answer R @ray . If you resolve with oil leak please let me know because I don't know what to do anymore.
did they gave you a bike to ride while you wait for parts? or is your bike still working with a leak ?, Honda really dropped the ball with these bikes.I'm still waiting for new crankcase/engine case whatever it is they plan on doing haha. pretty fed up with it which is a shame really because its a fun bike. Even contacted honda directly but they haven't been much help either.
That drop is normal. Anything more (or while the engine is running) is an issue.
Coolent yes, oil no....The pump has a weep hole on the bottom. Service manual states a drop or two there is totally normal.
Thats kinda sad that your experience is identical to mine firs pump water and oil second pump only oil next week they are going to install the 3rd and let me tell you if there gonna be a 4th im getting a lawyer im done with honda they fucked up with this bike and I'm not gonna take it anymore+1 for the water pump issue.
I noticed a small amount of oil/coolant after every ride hanging under the water cooler.
(Picture of old pump)
I went to the dealer and showed them, I also told them I had read about the issue here.
They replaced the water pump under warranty.
At first, the issue seemed to be fixed, but after a few 100 km's I noticed it started leaking a bit again after every ride.
(Picture of new pump)
It's not as much as the first time and seems to be only oil this time, so I'm going to wait a bit to see if it gets worse before I bring it back. If it stays like this I will only bring it back after the summer, because the bike works fine and I don't want to spend my vacation without the cbr.
