I tried to model that plate and the 6mm radius at the mounting tabs is a no go... Maybe 4mm?View attachment 8586
-Did some measuring and made a quick sketch this eve. Now that I'm back at work, i'll mill up a couple of these plates. -and maybe make a better drawing for you all?
Yep, looking at it now, we only have 10mm to work with there. I'd keep the R-6 around the holes and go R-4 on the inside corners. (unless we make it fancy and cut less than a 180 deg radius around the 7mm mounting holes...) -It was pretty late when I sketched this up.I tried to model that plate and the 6mm radius at the mounting tabs is a no go... Maybe 4mm?
Yep, -Gotta use it wisely!Someone had some free time!![]()
I'll buy a pair if you are selling and worthwhile (for both of us).View attachment 8586
No, not anything affordable anyway. Best process for this is to machine from a piece of metallic stock.Wonder if a 3d print would hold up to vibrations.
