CBR650F Phone, sat nav wiring
Wayne p
Oct 19, 2019
Liverpool
Have got this ser up for a phone, sat nav (last owner)
Is the a 12 bolt feed under the seat which will only be live when the engine running
It is straight to the battery so will have removed the wiring block every time l stop for some time
Dont what to blow any ECUs on this C13C1078-EA7B-497E-8E10-EE6E31522F83.jpegC13C1078-EA7B-497E-8E10-EE6E31522F83.jpeg
Rafe
Oct 1, 2019
On the F there's a switched 12v accessory port in the front by the headlight assembly. There is one in the tail on my CBR650R but not sure about the F.
Some info here on it's location if you wanted to rig it up so that it comes on/off with the bike.
Wayne p
Oct 19, 2019
Liverpool
Yes that has worked .
Did find that the wiring plug under the dash clocks the wiring pushed out of the block
one is 12 volt , one is the earth
Thanks for the information Rafe
