- Aug 6, 2022
- Riding Since
- 1995
hello, just joined the group, looking for some kind of list of needed tools for my cbr650f, any suggestions on what i need? bought my bike used and there
is no under seat tool bag
So you’re aware, all US Hondas have come with basically nothing from the factory in the tool kit since around 2011. You can find a microfiche and buy them from Honda for around $75 if you want them, however. As cheap and flimsy as they are, for a roadside kit, they’ve never failed me.hello, just joined the group, looking for some kind of list of needed tools for my cbr650f, any suggestions on what i need? bought my bike used and there
I suggest a set of combination spanners/wrenches, a socket set, a set of hex keys, an oil filter tool, torque wrench and a tyre pressure gauge. The maximum torque that you need to measure for routine maintenance is 98 Nm for the back wheel nut. For the back wheel you will need 22 and 28 mm sockets, which may or may not be in your socket set. There is a manual available from this website. If your want more detailed advice, get the Haynes manual (#6461). If you do things according to the book, you will also need hex keys with a square drive so that you can tighten hex screws and bolts to the specified torque. Get a decent torque wrench. The cheaper ones can sometimes be significantly inaccurate. My wrenches are by Teng, made in Sweden, and come with calibration certificates. They are sold in USA, and I am sure that there are other equally good brands.hello, just joined the group, looking for some kind of list of needed tools for my cbr650f, any suggestions on what i need? bought my bike used and there
Thanks for the reminder Brammers, just bought a set of these, although the only screws I have seen so far on the bike are the cap of the Brake reservoir? I can see how easily it would be to mess these up with a Phillips after comparing with the JIS. It is close enough that you may think "I can get that out"If you are planning on doing real work, a JIS driver set is also critical to avoid stripping the heads off of what look like Philips screws.
