Once blocked the reeds can't flap which is 99% of the noise.
AsOnce plugged I should have no further issues with the bucket of bolts sounds coming off throttle right? Or do I actually need remove the reeds and disconnect the solenoid to avoid the noise. That's my biggest problem/complaint
I ended up buying like 4 sizes of these from home Depot and none of them fit perfectly. I can't remember which size I used but I had to shave off some of the rubber to fit perfectly. If you can afford to drop $5 on a few of these sizes one of them will work. https://www.homedepot.com/p/Everbil...em_mobile-_-202975137-_-204273762-_-N#overlayAnyone know the size of the hole in the air box that needs blocking on a 2016 cbr650f? Want to get an appropriate sized plug before I start the job of changing air filter and also plugging the PAIR hole in the air box. Chee
You’re not missing anything, there are different ways to block off the PAIR valves, the plates you and many other bought, blocking the rubber lines (either the two on top of the existing plates or the one on the air box), placing caps on the existing plates.Hey guys, I'm finally getting around to doing the PAIR delete in my '18 CB650FA (Thailand model). Everything is going smooth. I have a SmartMoto kit here in front of me. I've spent several hours reading all these threads and checking out info elsewhere, gaining knowledge of the task.
What I'm here to ask then, is what is the actual purpose of the block off plates? I understand one can remove the reeds if they really want to, although no real reason. And the block off plates would serve as a true delete, but what is the difference between block off plates and just capping the ports on the existing reed covers?? The new SmartMoto kit has the recesses and also comes with a resistor installed in a plug, which is a bonus. Xaos636 did something similar in post #82-83. I've removed the pump and the lines, but the two lines attached to the reed covers are not wanting to come loose, and have now about an inch gap between them and it looks like I could place a rod between them and clamp it down. Or do as Xaos did, using a singular piece to connect and therefore close the loop. Or better yet, just place rubber caps directly on top of the reed covers in place of the old air lines??
Once I reached this point, I just began to think, why did I spend over 100 Euros for these two small aluminum plates if they're not really necessary. The pump is gone, the reeds are closed, the resistor is in place, the cat is gone.... I decided to sleep on it before going any further, and see if anyone will chime in to point out something I may be missing.
yeah, considering there are easier methods, I guess the plates aren’t really providing much greater benefits. Only a “cleaner job” since some parts are removed.Thanks Fritz,
I'm confident to do the job, but once I had my own eyes on it, I don't see any benefit to these plates, when some simple rubber caps on the reed covers will do the job perfectly.
A note on the SmartMoto kit:
Without taking off the protective sheath over the resistor, I can't determine if it's the proper spec. Hopefully they got it right.
Here is where I've landed. I wanted to use a single rod to plug both holes, but didn't have anything suitable. So as you can see I've plugged them individually. Now on the subject of the resistor connector, is my wrap job overzealous? Of course it's meant to protect the resistor, but is there a problem in terms of overheating, a lack of heat dissipation?I think you’ll be just fine.View attachment 11567View attachment 11570Here is where I've landed. I wanted to use a single rod to plug both holes, but didn't have anything suitable. So as you can see I've plugged them individually. Now on the subject of the resistor connector, is my wrap job overzealous? Of course it's meant to protect the resistor, but is there a problem in terms of overheating, a lack of heat dissipation?
Nice thanks for the feedback. With the newer smart moto kit did they provide all the plugs and bits that are required? Did you have to scavenge anything to complete the job?Alright, she's back together. Went for a rip. All is well. To be honest, there isn't a mega difference. I'm guessing different years and regions has a lot to do with it. For instance, judging from the 2014 Service Manual (because there isn't a newer one, right?), my Thai model is the only region with an EVAP system. Curious to know about newer models, whether they do or not. I left that system alone for now, not sure if there is anything to be gained from removing it.
But the pump noise is gone, obviously, and the reed noise. It's a bit smoother in the alleys around my house, but there is still a bit of a lash if you're abrupt with the throttle.
I used the resistor from the kit and that is all. Glad I did it even if just to eliminate to obtrusive noises. I feather the clutch and rear brake in these situations anyway, so maybe that's why I didn't have as big of a problem with it from the outset.
Thanks to all in this thread and site.
