Question for those of you that have models with the slipper clutch - Does the slipper clutch eliminate engine braking or does it only limit it to a point just prior to the rear wheel breaking loose? Short of trying to break the rear wheel loose how do you test the function of the slipper clutch? I can't find a good answer searching and if I didn't know better I would have no idea that my 2019 CBR650R had the slipper clutch installed. I still have tons of engine braking (relatively speaking - it's obviously not my old 996 Superhawk), and have felt zero slip even during some aggressive downshifts and one that resulted in rear tire side slide that was very nearly a low side event. Just curious on everyone's thoughts and whether this is normal.
