- Sep 21, 2019
I'm new in this Forum, and own a 2016 CBR650F. I crashed my bike in 2017, the clutch cover case took the damage and cracked. I replaced the housing and the bike wouldn't start after that. I took it to a recommended mechanic in town, and after 3 months having it in their shop they said it was the computer and kill switch. Recently the clutch burnt out and I rebuild the clutch pack using upgraded disks after feeling the OEM quality. Installed the clutch cover, and cracked engine, and didn't start. Kickstand was down, in neutral, pump was turning on, have spark, but wont start. I thought it probably had to do with the tip over sensor, but read that the fuel pump won't turn on if it was bad. I doubt the solution is the kill switch and computer because I never recieved a work order bill from mechanic and they had accidentally thrown the old parts away. Is there a trick after replacing the clutch cover case or did I miss somthing after opening up the system.
